I bet he sees the PM before he sees your post!!
Fun2av8RC,
Here are the files you need. The AV applies to my Pete n Poke and will make it fly as close to the way the Pietenpol Air Camper should as I can make it. Wings, tail feathers, etc. are different, but RF uses the raw shape of the fuselage that's in the 3D model and it is still based on the Poke's. I gave the physics model a 7' wingspan and put a Saito 72 up front. The 3D model is of course still the PnP and that is what you see, but if you look in the editor you'll see shorter but wider wings than are being used in the physics.
The CS file is just an export of the Pete n Poke's color scheme renamed Mr. Sam. This gives you the files to edit to achieve a repaint to look like your real plane. To make this process easier, I've also included a multi-layer Photo Shop file (just remove the .rfx extension and edit it with a paint program).
Enjoy,
Doug
Could someone please do a RC model of Gustave Whitehead's first airplane to fly? Much info here http://www.gustave-whitehead.com/
A little more research revealed two full size replicas were made and reportedly flown, one in the US, and one in Germany. These links show a few pictures of the 1986 US version:
http://www.thesoundadvisor.com/2012/09/22/mysteries-at-the-museum/#!prettyPhoto
http://www.ctpost.com/local/article/Aviation-bible-Whitehead-first-to-fly-4348050.php#photo-4316178
I don't know I anyone else noticed but the aircraft that is on the swaps is not a B-26. It's a Douglas A-26 Invader. The B-26 is an entirely different aircraft built by the Martin company and went by the name Marauder.
KE has brakes set up on some of their jet models. Have you looked at them?
Why is this question not in it's own thread?
Now, as was being discussed before. The Martin B-26 marauder.
I will be looking for an R/C and if I can, I will be digging up as much info on it as I can.
