I noticed that when on the ground, but with ArduPilot in control there is pilot input at 300Hz. The fact the aircraft keeps hovering also means the motors are still being controlled (quadplanes don't hover for long without changes in motor demands).Speaking to the aircraft going transparent in multiplayer...THAT is what happens when an aircraft sits for about 10-15 seconds...???
I tried upping the strength multiplier on the landing platform to 1500% (the max). No luck yet. I've never tried creating a runway to know how you setup the physics for it.I`m also wondering if/is it possible to give the landing platform the physics/hardness of a runway so the quads skids don`t sink into it.
I have some concerns about the aircraft successfully resting on a moving vehicle. I would expect it to make contact and receive impulses. But it may end up jumping around a lot, particularly with the discontinuous motion that tends to arise from networked multiplayer.If we did this, then would the collision physics work to allow the aircraft to sit on the ship while it moves?
Interesting. I wonder why collision isn't working (when not ghosted). I know that we experience mid-airs on a fairly regular basis when doing multiplayer testing. Maybe that changes when the contact is very slow. There are a lot of provisions to prevent collision when spawning in at common starting points. I'll have to investigate a bit to comment more knowledgably.This is our attempts so far:
This part is just FYI: The strength multiplier only controls the propensity of a part to break off. Setting it to 1500% means that the part will never break off. That's probably a good idea here.I tried upping the strength multiplier on the landing platform to 1500% (the max). No luck yet. I've never tried creating a runway to know how you setup the physics for it.
I'm not sure. Guessing without digging into code, this will either be very possible or nearly impossible. I'll have to investigate before giving any encouraging words.Jeremy, any chance we could use two flightaxis connections with multi-mode?
