why read? because every question you've asked was answered in this thread, weeks before you asked, including why there is not an F-22 in the particular five files that you installed.Of course not...why read? I imported all 5 files and none of them have a F22...unless I'm blind...I could be with this new Monkeypox
that's probably best, since they can't get you an F-22 for RealFlight anyway.f that I'm not giving any more money to the Chinese
I'm curious why you brought up the Chinese. Did someone here suggest giving them money or buying something from them? if so, I somehow missed it.f that I'm not giving any more money to the Chinese
well it's good that we have a rational-thinking, in-touch-with-reality fellow on this forum now.China owns everything...enough Politics...sorry...wait...North Korea just launched a missle over Japan...crap...gonna need that F22 it turns out....hahahahhaahah
expansion pack two (CD) which includes the F-22 is not compatible with EVOIs the Expansion Pack #2 compatible with RF Evolution?
It’s a stellth aircraft, that’s the whole point.where's the F22?
As far as I know the expansion packs "are not" compatible with RF Evolution. I seem to remember for RF Evolution they moved to a 64 bit application which broke compatibility with the older RF. Which I also seem to remember is why they put most of the expansion pack models into Evolution. Hopefully someone else can confirm this.are the expansion packs compatible with RF Evolution i cant get it to work
@Reemo_2001, it sounds like to all appearances absolutely nothing is happening--you never see the EP2 installer appear, and you receive no error messages of any kind--is that correct?
Make sure RealFlight is not running when you insert the EP2 disk or when you attempt to manually run setup.exe on it. If you have a non-Steam version of RF9.5, also make sure the RealFlight Launcher is not running, and neither is any other RealFlight product installer. Any of the above will cause the EP2 installer to silently exit.
If you have more than one version of RealFlight installed, the EP2 installer will scan for all of them and display a small product chooser dialog that enables you to select for which version of RF you want to install the EP. If this dialog appears behind some other application window for some reason, it would be very easy to miss--especially because it does not cause anything to appear in the Windows task bar that you could find and click. If you do have more than one RF installation, then I suggest exiting/minimizing all other software when you attempt to install to eliminate this possibility.
We took steps to mitigate false positives from antivirus software in this scenario, but it is still possible that AV software is interfering. That's something else you can check.
