How to add flex planes
I am wanting to add flex planes.how do I do this
A. Download the EA entire aircraft file for the above colour scheme ...it's on the above link...
Then go back to this link above and download this ...you'll have 2 files...
1. EA FILE (entire aircraft)
2. CS file ( colour scheme)
B. Then go to Realflight settings ESC key on RF Evo...
C. Select ' My Realflight '
D. Select. ' Import'
E. Select ' Realflight Archives'
F. Go to download files where you or where you downloaded the EA file and the CS file...
G. Install the EA file 1st then once installed install the colour scheme...
If in doubt always install the required EA file 1st before any colour scheme.
Ps if you click on the GREEN TEXT at the bottom of the screen on the left when you install it it will open the aircraft you've just installed without having to look it up in the index.
If looking at the "Flex Innovations Edge 540 Green_CS" linked above, in the middle of the screen is the text "This color scheme requires". Below it is a link to "Extra 330sc_EA". That is the one to install first.
"EA" (Entire Aircraft) are usually ones made by a user and uploaded. Stock planes, ones purchased from Steam, or included in really old Expansion Packs or Add-In supplements will be listed as such.
