Altitude Radial Rocket
From Wikipedia, the free encyclopedia
Radial Rocket
Altitude Radial Rocket RG
Role Amateur-built aircraft
National origin United States
Manufacturer Altitude Group
Status In production (2011)
Number built 6
Unit cost
US$74,500 (RG model, kit only,2011)
Altitude Radial Rocket TD
The Altitude Radial Rocket is an American amateur-built aircraft, produced by the Altitude Group of Overland Park, Kansas. The aircraft is supplied as a kit for amateur construction.[1]
Contents
1 Design and development
2 Operational history
3 Variants
4 Specifications (Radial Rocket RG)
5 References
6 External links
The aircraft features a cantilever low-wing, a two-seats-in-tandem enclosed cockpit under a bubble canopy, fixed conventional landing gear or retractable tricycle landing gear and a single radial engine in tractor configuration.[1]
The aircraft is made from composites. The wing span and area as well as gross weight varies depending on the model. The Radial Rocket's recommended engine power range is 360 to 400 hp (268 to 298 kW) and the standard engine used is the 360 hp (268 kW) Vedeneyev M-14P four-stroke powerplant.[1]
Operational history
By October 2012 five examples had been registered in the United States with the Federal Aviation Administration.[2]
Variants
Radial Rocket RG
Retractable tricycle gear model. It has a 26.8 ft (8.2 m) span wing, a wing area of 93.9 sq ft (8.72 m2) and a gross weight of 2,575 lb (1,168 kg). Construction time from the supplied kit is 2000 hours. Two were reported flying by the end of 2011.[1]
Radial Rocket TD
Fixed taildragger gear model. It has a 25.5 ft (7.8 m) span wing, a wing area of 90.8 sq ft (8.44 m2) and a gross weight of 2,550 lb (1,160 kg). Construction time from the supplied kit is 1900 hours. Four were reported flying by the end of 2011.[1]
Data from Kitplanes[1]
General characteristics
Crew: one
Capacity: one passenger
Length: 22.2 ft (6.8 m)
Wingspan: 26.8 ft (8.2 m)
Wing area: 93.9 sq ft (8.72 m2)
Empty weight: 1,720 lb (780 kg)
Gross weight: 2,575 lb (1,168 kg)
Fuel capacity: 65 U.S. gallons (250 L; 54 imp gal)
Powerplant: 1 × Vedeneyev M-14P nine cylinder, air-cooled, four stroke radial engine, 360 hp (270 kW)
Propellers: 3-bladed constant speed propeller
Performance
Cruise speed: 242 mph (210 kn; 389 km/h)
Stall speed: 70 mph (61 kn; 113 km/h)
Range: 1,200 mi (1,043 nmi; 1,931 km)
Rate of climb: 3,500 ft/min (18 m/s)
Wing loading: 27.4 lb/sq ft (134 kg/m2)
References
Vandermeullen, Richard: 2012 Kit Aircraft Buyer's Guide, Kitplanes, Volume 28, Number 12, December 2011, page 42. Belvoir Publications. ISSN 0891-1851
Federal Aviation Administration (28 October 2012). "Make / Model Inquiry Results". Retrieved 28 October 2012.
Radial Rocket
Number built 6
Unit cost
Contents
3 Variants
5 References
6 External links
Operational history
Variants
Radial Rocket RG
Radial Rocket TD
Crew: one
Performance
References
