This is the second modification I, Maverick, have done on the AR-6 Endeavor. It flies like a 3D plane because of the aileron, rudder and elevator modifications I did. As a suggestion I wouldn't mess with this plane too much because the weight is balanced such that it is able to do insane maneuvers without breaking anything. It is called the SMOKE MACHINE for a reason...there are 25 individual smoke components on the plane. 12 on each wing and one on the 150cc engine. WARNING THIS WILL PISS PEOPLE OFF IF NOT FLOWN CORRECTLY, IT WILL GET YOU BAN FROM MULTIPLAYER SESSIONS(Except mine of coarse). BE RESPONSIBLE.
