J
Blade CP Pro Brushed - GWS EM300 - Flat Blades_AV
Eflite Blade CP Pro with G90 Gyro Upgrade, stock motor, and flat blades.
The gear ratio has been modified to 18:1 which is the ratio for an 8 tooth pinion on the stock main gear this keeps the RPM in the 2200-2500 range. If you want higher RPM, the gear ratio for a 9 tooth pinion is 16:1 and a 10 tooth pinion is 14.4:1. The tail prop has been modified to the correct diameter.
I think this is pretty close to a stock Blade CP Pro. Let me know how you think this AV can be improved. Thanks.
Original physics contributions courtesy of:
RCHeliAce, HX3D014, Opjose
Blade CP Pro_EA
Author
jaeysson
Views
1,673
First release
Last update
RealFlight Version
3.50.065
