Smoothest giant scale RC you will ever fly. ATA means Airspeed Telemetry Automation. Elevators, flaps, and gear automatically respond to your airspeed, keeping you configured and in trim throughout the flight, so you can concentrate on perfect approaches and landings. Leave gear switch down, gear will begin to retract as you pass through 115 mph, and then extend as you slow below 110 mph. With the knob, choose flap setting (top of knob full left = max flaps at low speeds). If you wish to fly clean at lower airspeeds, you can override the ATA system with the gear switch and the flaps knob. The ATA system can not be overridden to fly dirty at high airspeeds as this would be dangerous. Left 2 position (dual rate) switch engages reverse thrust at low throttle settings (switch towards you). 3 position switch controls air brakes for very steep approaches. Forward elevator for wheel brakes. Thanks to Lex for the excellent physics and graphics of the original EA.
Find all 25th Century airliner files by searching “-=-airliner.” Find all 25th Century files by searching “25cent.”
25cent -=-fixed -=-airliner -=-multiengine -=-jet -=-scale -=-fast -=-17-1
