Built by special request
The E-flite® Eratix™ 3D 25e ARF is a 3D-capable sport plane designed to make the transition from sport models to more challenging 3D aircraft a lot less demanding. Its large wing area and light wing loading offer very forgiving flight characteristics, especially in slow flight. It’s also compatible with a range of motor and propeller sizes so you can fine tune the power and performance to your skill level. Both the E-flite Power 25 and Power 32 brushless outrunner motors bolt to the firewall without any modifications. Experienced 3D pilots will appreciate the uniquely designed, machined aluminum 3D control arms that can handle the rigors of high-torque mini servos and large control throws. Sport aerobatics or stick-bending 3D, the Eratix 3D 25e is up for whatever you are.
3D Model by jeffpn
Colorscheme by Maj. Numbskully
Physics by jeffpn with the usual tweaks from dhk79
Additional artwork by dhk79, inspired by an idea from td9cowboy
Standard 4 channel control
3D Model by jeffpn
