This is an 3D EPP foam version of the Zivko Edge 540 created for RF6. It hovers nicely, does clean knife edges with almost no coupling, and flies well inverted. I tried to play the physics in the EA pretty straight, without over sized rudders, increased prop wash, etc.
The model has working servos, pushrods, and control horns as befits a foamy.
I created the model and the CS. However, I did use parts from Flexible (the motor), Abaser (servos, pushrods, control horns), and AlternativeRC (the Esc).
Many thanks to the guys in the designers forum who helped me get this off the ground. The help was much appreciated.
This has been tested under RF6.5 and works.
