G
F-86 Sabre (Turbine) VG_AV
"Variable Geometry" F-86. Wings rotate using the 3-position switch for thrust vectoring (fuselage vectoring?) that gives slow flight, tight turns and spins. With a little practice you can do vertical rudder-first spot landings (crashes). It's quasi realistic: stock engine and weight and the physics model matches the visual model.
F-86 from RealFlight G3
Reactions: helohero
