Highly modified wireframe!
THIS IS NOT AN EDGE, it just looks like a old PAU Edge
I started messing around with the PAU Edge years ago lost my edit from 2019 that flew EXACTLY like my AJ Aircraft 104" ARS 300 which was the MOST FUN 120cc build I ever had of my many 104 ARS's I have owned and crashed.... I tried something new and wasn't high enough back in July 2019 XD.
Since having to start over I ended up down this path with this edit. I currently am experimenting with a newer version(s) to get the throttle response down. Only thing it doesn't do very well is tumble.... You just need to "Fly through" the tumbling with throttle. Joe Szczur and I are actively working on getting the "Tumbing" and throttle response down which has proven to be the biggest challenge with RF.......
This edit is a Double taper wing with SFG's under the PAU Edge Visual Aircraft, with inspiration from Andrew Jesky's AJ Aircraft design mindset with my own twist.
