inky00
Piaggio Pegna PC-7_EA
Piaggio Pegna PC 7.
A truly remarkable design, the Piaggio P.7 or Piaggio-Pegna P.c.7 was built for the 1929 Schneider Trophy contest. A cantilever high-wing monoplane with long slender fuselage, it had twin hydrofoils instead of floats and was intended to float with the wing resting on the surface of the water. While water-borne it was to be driven by an ordinary marine propeller connected by a shaft and clutch to the rear of the 723kW Isotta Fraschini Special V.6 engine. Once sufficient speed had been attained to lift the aircraft on to the hydrofoils and the normal air propeller was clear of the water, this latter propeller would be clutched-in, the marine propeller disengaged, and a conventional take-off would follow.
In practice, problems with the respective clutches prevented the P.c.7 from ever taking off, and although water trials were conducted on Lake Garda by Dal Molin of the Italian Schneider team, the construction of a second aircraft was abandoned.
Realflight Controls:
Aileron,Elevator,Throttle and Rudder as Normal
Top Right Switch:Changes between Water and Air Propellors
Start with the switch towards you and once your up on the Hydrofoils flick the switch to change to the airscrew and your away.
Front Left Switch: Dual Rates
I have named the pilot with the ~CS_2STROKE name so if you dont want him in the cockpit goto "Engine" in the editor and change "Engine To Show" to "None".
3D Model,Colourscheme and Physics model by
Mark(Inky00)England
Normal and Specular Maps Included
Author
inky00
Views
2,691
First release
Last update
RealFlight Version
4.50.021
Latest updates
  1. Images
    Images
