Realistic sounds, realistic rotor RPMs, realistic heavy feel. Smooth positive controls. This is the V-22 you’ve been waiting for. Enjoy the true scale experience of this finely tuned scale model. ramp control is moved to the dual rate switch so the 3 position switch can be used as a tilt control override, allowing you to concentrate on flying while the rotors tilt to your desired setting at the flip of a switch. With the three position switch in the middle, the knob controls rotor tilt the same as the knife edge model. Move the switch to the up position and the rotors slowly transition full up for hover operations. Move the switch to the down position and rotors transition to full forward for max speed. With gear switch down, rotor angle is limited to no more than 45 degrees down, making running take-offs and landings a breeze. With a little practice, you’ll be flying like the real thing in no time. Find all 25th Century military files by searching “-=-mil.” Find all 25th Century files by searching “25cent.”
25cent -=-mil -=-rotor -=-turbine -=-scale -=-twin -=-16-8 -=-+
