That is completely normal.
The background is "projected" onto the collision buffer object, so you can not see things behind a net, etc.
All sims do this.
To get around that, you would need an actual 3D object that you can look through instead.
That means in order to do the field you are talking about, you would have to take photos of the airfield WITHOUT the net in place, import that as your airport background, then insert a 3D net you've created in place of the original net.
This has been done with several of the provided Realflight airports.
