Can't start after crash.
pache11
An unexpected error has occurred. Would you like to send error report?
I can't get it to run 8 HH edition still runs fine.
pache11
Is there a way to restart or reset back to defaults? I uninstalled and reinstalled with no success. The same error occurs. I have run this for a couple weeks now fine. Adjusted quality settings and was running fine for a couple hours and then locked up. Now will not start.
technoid
You might try this.
With RealFlight Evolution NOT running.
1. Open Explorer and Navigate to Documents\RealFlight Evolution.
2. Right Click and Hold the RealFlight64.ini file and drag it to the Desktop then release the mouse and select Move.
I'd move it to the Desktop so you can move it back if you want to.
Now try to Start RealFlight.
pache11
I did that and it did not work. I finally found that if I removed the Interlink controller from the usb and restart I would get the no controller found message. Reinserted the interlink into the usb and Evolution now operates correctly again.
technoid
Great I'm glad you're working again.
