Controller-Trim runs to the left edge
Tomsagiplatz
Hi, since a few days, the trim from the right Stick runs to the left edge and stays there.
You can not move em back in the midle. Calibration won't help and the reset from the App won't either.
Is there a problem with my controller?
Assuming that you're using InterLink DX for a controller? If not, please tell us which controller you're using.
When you calibrate, does the calibration process appear to work properly? Does the bar graph for the aileron/elevator channels sit in the center when the stick is centered, or is it off-center?
You can get a little idea of what RF thinks is going on by turning on the Radio Gadget. That will show you on the screen where it thinks the stick is at and where it thinks the trim is set. Simply go to the Gadgets menu and check Radio to turn it on.
