Thanks guys, the kind words are appreciated.
Came across a Max 2018 issue (proved to be minor, but was a bit scary at first) recently. Passing it along in case others encounter it.
I decided to change the settings to increase the resolution of images.
It's probably been lower since the new PC and Max 2018 were setup, but since at present I'm not building from plans, I've ignored it.
In the past versions of Max, changing the driver made the difference.
After changing drivers this time though, Max 2018 would not run.
Wonderfully, one can still get to a command prompt, even in W10.
Carefully typing in the command string yields a dialog box to select a driver.
Worked fine and Max is happy again.
The correct adjustment is the display resolution.
2048 worked well for the images on the new PC.
Not sure if this has been mentioned before, but thought I'd pass it along for any newbies encountering this issue.
Enjoy a great week.
