Loneryder787
Need Advice on the Best NX10+ / WS3000T / RealFlight Evolution Setup
Hello everyone,
I’m relatively new to RealFlight Evolution and I’m trying to build a setup that closely matches how I fly my actual Spektrum-equipped aircraft.
My Equipment
Aircraft I’m Flying
How I’m Currently Organized
Rather than creating a separate transmitter model for every aircraft, I’m using one dedicated NX10+ model for RealFlight and then maintaining multiple WS3000T controller profiles in RealFlight, such as:
Each profile has its own switch assignments. For example, my Trainer profile uses:
My Warbird profile uses a different switch layout that’s more appropriate for those aircraft.
My Goal
I’d like the simulator to behave as closely as possible to my real aircraft so I can build good habits and muscle memory. Ideally, I want the switch assignments, rates, and flight modes in RealFlight to match what I’ll use at the flying field.
My Questions
I’d really appreciate hearing how experienced RealFlight users organize their transmitters and controller profiles to create the most realistic training experience.
Thanks in advance for any advice!
Hello everyone,
My Equipment
- Spektrum NX10+
- WS3000T wireless USB dongle
- RealFlight Evolution
Aircraft I’m Flying
- UMX Timber X
- AeroScout 2 1.1m
- Turbo Timber 1.5m
- (Other similar E-flite aircraft in the future)
- WS3000T – Trainer
- WS3000T – Warbird
- WS3000T – Advanced
- Switch A – SAFE On/Off
- Switch B – Beginner / Intermediate / Expert rates
- Switch D – Flaps
- Switch H – Throttle Cut
My Goal
My Questions
- Can the dual rates and expo be modified on aircraft such as the UMX Timber X, AeroScout 2, and Turbo Timber 1.5m (excluding aircraft like the Pitts if they are locked)?
- If they can be modified, where is the best documentation that explains how to do this? Is there an official guide or a good tutorial?
- Is my approach of using one NX10+ model with multiple WS3000T profiles considered good practice, or is there a better workflow that experienced users recommend?
- Should I be making most of my adjustments in the transmitter, in RealFlight, or a combination of both if my goal is to closely match the behavior of my real aircraft?
- I’ve noticed that some RealFlight aircraft seem to behave differently than the generic setup instructions suggest, and some appear to have limited or locked flight-controller settings. Is that normal? If so, how do experienced users work around those limitations?
