Well Legoman, I tried editing the center 5 from 1000 to 1450, then, went to exit the ini file and got a pop up window directing me to "save" or not (just like in the RF editor), so I clicked "save" and the file closed out as expected. Then I started RF and tried recalibrating the TX making sure everything was centered, went through all the steps, and still no luck getting the left slider to center on the bar graph at all, it`s either 0% or 100% no in between, I`m wondering just for comparison, what # in the ini file represents the RIGHT slider....?????..., ALSO there`s an "edit" function in the "calibrating window" and the sliders channels are 14/15 for the lft/rt sliders respectively, I`m just curious as to why those aren`t the #`s in the ini file the would need to be be used in order to edited the sliders EXAMPLE : I`m editing center 5 instead of center 14 for the left slider...??? On a side note, I checked the ini file today, AND the # that I edited (center5) is back to 1000, Not the 1450 that I put/edited in and "saved" AND the min/max 5 #`s didn`t change either
..??? I`m beginning that the slider is just plain
up.
