This is textured to be the Electrifly SS-35 BL ESC, but by simply modifying the texture, it can be almost any ESC you want, it is .3ds format, zipped up with the texture targa, as well as the .psd, and a max file thrown in.
After locating the CLAM_HOOK under the lifting vehicle, you can locate the tops of all the cables, just under the top of the blade hub, on center.
Be sure to add fuse components for the CLAWS, with strength at max.
Allso set the weight on all pods to .04, and other values to 0 or 1
Mejzlik Carbon Fibre Propeller,1316 tris.For use with Static planes.
The Zip file contains the max file,3ds file and the TGA texture file.
.RFX added to filename to enable uploading,simply remove .RFX from filename and then unzip as normal.
E-Flite Park 250 motor,5618 Tris.
Completely setup and ready to use,all pivots and naming Done.
I lost the first Materials for wings I did, so I made another one. I have included three of Dougs colors. I have included lables so you know what is what. I have included screen schots of how to see the properties of any color. Delet the .g3x to be able to unzip.
