This is a somewhat modified version of Boof's Pilot, intended to be more World War I like. Included in the zip are the max file (highly recommended), obj, 3ds, and fbx files. If you cannot use the max file, use the fbx file if possible. The 3ds file is mapped, but you will need to rename PilotFigure.tga to PILOTFIG.TGA and then point to it. The .obj version of the file has a slight flaw where the leg goes through the bottom of the coat. You might need to fix that depending on the angle you are using. (Probably not).
The triangles come in at a modest 3056.
Enjoy!
