Thank you for the reply. But, it did not helpHello, a few weeks ago I had the same problem, I sent an email to technical support and they informed me that in the installation the windows firewall must be deactivated and once the installation is finished put everything as it was before, that way I solved the problem, no I know if it will be your case or not, I hope you can solve it soon, greetings!
ops, there are meny users in the forum, maybe anybody can help you, good luck bro!Thank you for the reply. But, it did not help
I can change the airport, and it exit with aircraft that I select. I have used interlinkDX and the mouse to try and select another aircraft. When I bring it up, the last airport I that I chose is display with the aircraft that remains active. I am able to this aircraft with no issues. When I try to chose for another aircraft the list comes up I select one and acts I like hit the exit button.A few things that might help narrow the problem down:
Does it happen when you select another airport or scenario?
Does it happen if you select any aircraft or a specific one?
Does it make any difference if you select aircraft with the interlinkDX or mouse or keyboard?
What processor and Graphics card are in your PC?
Which airplane and airport does it start up with?
Thanks for the encouragementops, there are meny users in the forum, maybe anybody can help you, good luck bro!
Thanks!!!!!!!!!!!!!!! I've been using RF since at least RF2, and I didn't know I could do that. MUCH better now!Ok, you can configure those parameters from the menu, then I'll explain how to do it.
In the Real Flight menu go to "simulation" and then go to "specifications" once there you must click on "console" and you will see the item "ERROR" there you can configure the size of the font, the color and the time of duration of the error message, as well as the background color of the message, I hope I have helped, greetings!
