RealFlight Reset SOAP Envelope
liamf555
I've been following the ArduPilot examples to implement a Python interface. For my application, I need to be able to reset the RealFlight simulation. I don't believe this is implemented in the ArduPilot examples, however the Q&A suggests this is possible. What is the soap envelope to call a reset?
Thanks in advance.
Thanks in advance.
check my post here for all available method i've found so far ;)
fast answer: yes. i uses
<ResetAircraft><a>1</a><b>2</b></ResetAircraft>
inside <SOAP:Body> section.
I've successfully implement RL in RF with this reset method. hope it helped :)
Thank you!
I've just noticed you say you've implemented RL using flightaxis, that's similar to what I'm looking to do. How have you implemented it, are you using Python?
yup. i implemented it by creating an environment based on OpenAI to train the aircraft. and yes, im using python. first, i created the API to make my work easier, then i use the API inside the environment such as getting, sending the data from RF, etc.
