I have the same problemHow do you get the helicopter blades to rotate? Throttle cut is off and no response?
I’m using the controller that came with the sim Slt-6Which controller are you using?
RealFlight has a heli throttle hold function on RealFlight Channel 9 that applies to all helis. If you're using the InterLink DX, that's switch H. If you're using your own controller, you'll want to set things up on your radio and then in the RealFlight Controller Profile to map RF Channel 9 to one of the channels on your radio.
Thanks that solved it pressing the J keyWhat are you doing to "try throttle hold"?
With only six channels to work with, you're very limited with the functions you can assign to the radio and throttle hold probably isn't one of them.
Fortunately, there's a keyboard equivalent for RealFlight Channel 9 - it's the J key. Pressing the J key will toggle RealFlight's throttle hold on and off.
Thanks for this, pressing J key sure worksWhat are you doing to "try throttle hold"?
