Tutor 600 helicopter Error
1024kb
Active member
Over the last few days, when I load the Tutor 600 helicopter I get an error:
‘The aircraft variant “Dazzler 46AX Smooth 3D“ cannot be loaded. It is based on an aircraft you don't have. ‘
Then the helicopter loads normally. I thought the Tutor 600 was a built in model so not sure what’s going on. Any ideas?
the dazzler is an add-ons aircraft. since the add-ons are not compatible with evolution so there is not way to add that plane to evolution. if you are in an older version of rf confirm that the add-ons have been added to you version of rf.
Thanks for the reply. I don't have any RealFlight addons so I guess that's why the error message is coming up. I have discovered that the error is not related to the Tutor 600 and comes up when I select other aircraft; seemingly randomly. I'm guessing it relates to one of the models I've downloaded from the swap pages, but I have no idea which one. I did a search of the swap pages for "Dazzler" and don't have any of the models found. I haven't downloaded any models that even look like a Dazzler either. I'm running RealFlight version 9.5s. Any ideas how I can find out which model is causing the issue?
Here is a list of my custom aircraft.
Code:
Mode                 LastWriteTime         Length Name
-a----        01/09/2021     18:50            378 A-10 Thunderbolt II Warthog.bse
-a----        12/06/2022     19:33            376 AIRWORLD F-104 STARFIGHTER 1.bse
-a----        03/10/2021     19:27            394 Align T-Rex 150LP Ultra Dominator.bse
-a----        28/02/2022     19:07            347 An-225 Mriya RF8.bse
-a----        23/08/2021     10:36            327 Avro Vulcan B2.bse
-a----        16/08/2021     21:29            311 Avro York.bse
-a----        24/04/2023     19:03            337 B-43 JetMaster.bse
-a----        15/09/2022     19:55            355 B-52H StratoFortress.bse
-a----        03/09/2021     19:00            371 Beaufighter TF X Torpedo.bse
-a----        03/09/2021     19:53           1210 BOEING 747.bse
-a----        03/09/2021     19:20            361 Boeing 787-9 DreamLiner.bse
-a----        16/08/2021     20:24           1203 Boeing B-29.bse
-a----        21/03/2022     20:51           1269 C-130_Hercules_Canadian_Forces_02.bse
-a----        10/09/2021     21:15           1208 CH-47 Chinook.bse
-a----        04/09/2022     20:43            327 Chitty Chitty.bse
-a----        03/09/2021     19:33            321 Concorde_HD.bse
-a----        03/09/2021     19:40            325 DeLorean_BTTF2.bse
-a----        22/08/2021     14:58            323 EF-111 Raven.bse
-a----        12/06/2022     19:38           1185 F-104_G.bse
-a----        16/08/2021     20:20           1217 F-117 Nighthawk.bse
-a----        16/08/2021     20:15           1208 F-14 Tomcat.bse
-a----        13/11/2021     10:06            359 F-15E Strike Eagle.bse
-a----        22/08/2021     15:05           1204 F-35B STOVL.bse
-a----        24/04/2023     19:15            327 F3A OREKA Plus.bse
-a----        01/09/2021     22:10            372 FA-18 Hornet Blue Angels.bse
-a----        01/07/2023     19:32            327 Flakpanzer IV.bse
-a----        25/06/2022     21:22            346 Flettner 282 test 10.bse
-a----        06/10/2022     20:50            355 Flettner 282 test 18.bse
-a----        19/01/2023     19:40            323 Flettner 282.bse
-a----        24/04/2023     19:10            327 Fly Baby Bipe.bse
-a----        19/01/2023     19:36            347 Galloping Ghost EP.bse
-a----        06/01/2024     18:55            323 MiG-21 bis.bse
-a----        21/03/2022     20:36            378 Northrop XB-35 Flying Wing.bse
-a----        20/10/2023     19:23            343 P-39 Airacobra EP.bse
-a----        05/06/2022     20:04            324 P-51 MK1a.bse
-a----        02/09/2021     20:05            387 Powered Paraglider Drop Cart.bse
-a----        11/09/2021     19:20            347 Realflight Clipper.bse
-a----        16/08/2021     21:11            328 RLU-1 Breezy.bse
-a----        01/09/2021     20:17            364 RockwellSpaceShuttleOrbiter.bse
-a----        16/08/2021     20:41            391 SAB GOBLIN 1000E (Lighthorse).bse
-a----        16/08/2021     20:56            377 SAB GOBLIN 500 (Lighthorse).bse
-a----        16/08/2021     20:37            383 SAB GOBLIN 570 (Lighthorse).bse
-a----        22/08/2021     14:49            431 SAB GOBLIN 770 Competition (Lighthorse).bse
-a----        16/08/2021     20:02            311 Sea Vixen.bse
-a----        08/09/2021     19:27            337 Sky Terror Mk-II.bse
-a----        28/11/2021     20:38            335 Spitfire XIV EP.bse
-a----        01/09/2021     19:15            331 SpitfireMKV.bse
-a----        01/09/2021     19:34           1187 SU-30MK.bse
-a----        24/05/2022     18:43            339 T-28B Trojan 20%.bse
-a----        19/05/2022     20:39            323 T-28C Trojan.bse
-a----        03/09/2021     19:11           1175 UF3.bse
-a----        21/03/2022     20:18            319 westlysander.bse
-a----        06/02/2022     09:31            315 XB-35 t 29.bse
Go into your RealFlight 9\Vehicles\Custom Vehicles directory and look for a file called Dazzler 46AX Smooth 3D it should have a ".rfvehicle" extension. You should be able to delete that file to get rid of it. An AV doesn't have an entry in the Custom Vehicles directory like EAs do.
Thanks found the file and deleted it, seems I was looking in the wrong directory, I found some custom aircraft in the CustomModels directory first and didn’t look any further, so never got to look in the CustomVehicles directory.
The error message has gone now.
I had a look in RealFlight.ini and interestingly there's still entries in there in the [BreakaPartCost],[Filters] and [AircraftColorScheme] sections for the Dazzler and aircraft I’ve deleted.
I'm glad that fixed it for you. The way it works is the YourPlane.rfvechile in the Custom Vehicles directory is the "physics" for the plane and an AV "only" has a physics file because an AV is only a modification to a plane's physics. An AV uses the original planes 3D and ColorScheme that is located in the Custom Models directory.
And yeah the realflight.ini file will have entries for all the planes you fly so deleting an AVs physics file, the YourPlane.rfvechile, won't clean out the entries in the realflight.ini file. I have went through the realflight.ini file in a text editor and manually deleted all the entries for a plane I deleted the way I told you, but you must be very careful when you delete those entries to only delete the lines with the planes name your removing. So I'd make a backup of the realflight.ini file before deleting a plane manually to have something to fall back on if you mess up.
