Hey other modelers,
I was talking with Cowboy about mapping multiple objects in max 9 and he said i need a download to do so. But, he doesn't know where to get it :\
I was wondering where i could find this?
THe way I've mapped multiple objects simultaneously has been to select the objects (ie both wings, ailerons, flaps) apply the unwrap UVW unwrap modifier and click edit. Then click mapping and normal map (apply the top/bottom for the parts mentioned above). Then position and rotate so they are all aligned for easy CSing. It is the same as single mapping but I select multiple objects using Ctrl + left click. Works just fine for me.
