This is a variant of the excellent A-10 Strike. It is 125 percent larger, and tops out at speeds of almost 500 MPH. I called it the Super Tank Killer for the six barrel gun in the nose, and the tank killing missile barrage. If you run into SAMs you even have flares to release to confuse the missiles. The gun is fired by the three position switch on the top right of the controller, the missiles by the same switch, opposite throw. The flares by toggling the Dual Rate Switch.
