M
Alpha 40E V2_AV
Alpha40E.
This model has been adjusted in various ways. The CG was moved, a wee bit of nose weight was added, NACA numbers for various items were adjusted, the number of degrees movement for various controls was altered, as well as a few other modifications were made. The end result is a model that flies quite well and in a fairly realistic manner.
Controls are as per the original model. Fly with the rate switch in the High position.
Alpha 40E_EA
