This is a tribute to the Cadillac Ranch, where some old coot likes to plant old Cadillacs like the planes are planted here. This AP was designed on the Boneyard map; first for visual pleasure and then for combat. The Carrier has been dry-docked here to avoid the frame-rate-killing water. The sky haze has also been set close to make the world a little smaller to help with the frame rates. This map has more spawn and game spawns than I care to count....and the game coins are a joke....enjoy.
P.S. If you sit on the carrier deck spawn long enough, you may see a mouse run across the deck from left to right, about two thirds of the way between your plane and the right hand catapult block.
