3D MOFO 2020!
E-flite Decathlon RJG(3D MOFO 2020! Edit)_AV
Here's another DLC I got off of steam as it was (before my edit) it could pull off some hovers and such the roll rate wasn't that bad either. All I did was change out the prop from a 10 inch to 12 inch pushed the 4s 220mah lipo to the back give it a little more throws on everything also I removed ''Safe Select'' I left AS3X on all the time since I noticed without it there was a whole lotta of bad coupling in knife edge flight which is understandable since this is a high wing plane. Anywho enjoy!!
E-flite Decathlon RJG 1.2m from RealFlight Evolution DLC
