This AV is a larger version of the E-Flite UMX WACO. It has a 48" span And in High rate it is capable of most all 3D flight. In low rate it is a very good aerobatic sport plane. And in AS3X Safe it is a great trainer and very easy to fly. So, this plane should be fun and enjoyable from the novice pilot up to the highly skilled pilot.
Channel 8 is AS3X. Switch towards you, stability off, middle is stability on, switch away from you is AS3X safe on.
Channel 7 is smoke on/off.
Channel 5 High/low rate.
Brakes on up elevator.
Numerous camera angles added for fun.
There are several color schemes available for it.
As always, Have fun.
Enjoy.
Enjoy.
