Gee Bee R-3 300cm with Moki 400cc 4 Stroke Radial Gas Engine by Spidernad.
Big Torque Radial and Improved Handling.
Several hours went into this variant, with the addition of some very realistic features including two levels of "Blown Engine" engine fire and smoke that eminates from the exhaust pipe recess under the fuselage at the cowl.
It flies very nice and I think you'll enjoy it as much as I do.
Please rate it if you like it.
Thanks.
Download my other planes at:
https://forums.realflight.com/downloads.php?do=viewmemberfiles&userid=50836
Addtional "Red Bull" color scheme available below.
Original model created by:
Gee Bee R3.3d model and colourscheme by Mark(Inky00)England,
Physics model by Ryan"The Kid"Archer.
Aircraft Specifications-
Seven Channels
Throttle
Ailerons
Elevator
Rudder
Fire / Smoke- Controlled by the 3-position switch on the top left of the InterLink controller.
Forward position = No Fire / Smoke
Middle Position = Small Fire / Smoke
Rear Position = Big Fire / Smoke
Engine Smoke- Controlled by the 2-position switch located on the front right of the InterLink controller.
Brakes- Just pull back on the stick.
Dual Rates- Controlled by the 2-position switch located on the front left of the InterLink controller.
Thanks.
Seven Channels
Throttle
Ailerons
Elevator
Rudder
