25thCentury
Harrier 33% scale2_AV
V2 - improved auto-transition elevator mixes. This ⅓ scale Harrier has great stability and smooth response in every part of the envelope. It’s perfect for true-to-life scale flying. You’ll find it a joy to hover and to fly at 250 mph. Be sure to check out Harrier_Carrier_Airshow_RC to see what this AV can do. Also available - Harrier_Desert_Camo_CS and Harrier_Night_Raider_CS. Enjoy.
Controls: With the 3-pos switch in the middle, the controls work exactly the same as the RF7 Harrier, but much smoother. By using the down position of the 3-pos switch you can go straight to full hover mode without touching the dial. While hovering, flip the 3-pos switch full up, and you will automatically transition smoothly to forward flight, leaving you free to concentrate on flying. Transition automatically back to hover by flipping the switch full down. Each transition takes a few seconds, giving you time to smoothly adjust the throttle, and position the aircraft as you like. The smoothest auto-transition to hover can be achieved by flipping the switch around 45 mph, about 20 ft AGL, gear extended, throttle - full down, and then inputting throttle and elevator as required.
Find all 25th Century military AVs CSs and RCs by searching "-=-mil," or all 25th Century files by searching "25cent."
25cent -=-fixed -=-jet -=-mil -=-twin -=-rf -=-scale -=-retract -=-aerobatic -=-fast -=-10-12' -=-2-4m -=-20-40lb -=-10-20kg 200+mph 300+kph -=-14-9
Harrier from RealFlight 7
Latest updates
  1. Images
    Images
