T
Mikado With Orientation Marks_CS
*** THIS COLOR SCHEME IS YELLOW/GREEN ***
Inverted Trainer: Mikado Hughes 500 with orientation marks to help newbs when flying inverted. The orientation marks can be helpful when practicing inverted for the first time, can also be used for practicing other positions. Use the ~ key in realflight to get into the console, then type bind g lockposition. Exit the console, then hit the g key on your keyboard while hovering. This will allow you to lock the heli in place if desired, so that you can practice without crashing. *** Focus on the nose of the heli while inverted and you will see that if you pull to the L (left) heli yaws left, Pull to the R (right) heli yaws right. Use the visual cues to help you keep your orientation in any position.
Mikado Hughes 500_EA
