Same as the ultra baja truck but with a shortened stabiliplatform on the end, and grip wheels. This allows you to do some monster backflips and frontflips at the expense of sacrificing pitch and yaw stability, so it is in fact more realistic and difficult.
This is the final version of the Baja modification. Features: Anti-roll coupling thrusters, semi-torqueable wheelies (thrusters + weight) for a wheelie hold the elevator and gun the throttle for a short burst then bring the throttle down, this works better on low rates. Refined weight, balance, and midair trajectory on jumps. Low rates on dual rates makes it easier to handle at high speeds of course. Reverse is on the 3-pos switch, up for reverse. There are no wheel brakes, you can add them if you want. This version is stocked with regular-friction normal grip tires. To change the grip, open up the wheels in the editor and increase the FRICTION MULTIPLIER for more grip, and decrease it for less (drift). To stiffen up the suspension, open up the FRONT GEAR and REAR GEAR, and increase the STIFFNESS. Enjoy! Many thanks to the creator of this model!!
