This is the final version of the Baja modification. Features: Anti-roll coupling thrusters, semi-torqueable wheelies (thrusters + weight) for a wheelie hold the elevator and gun the throttle for a short burst then bring the throttle down, this works better on low rates. Refined weight, balance, and midair trajectory on jumps. Low rates on dual rates makes it easier to handle at high speeds of course. Reverse is on the 3-pos switch, up for reverse. There are no wheel brakes, you can add them if you want. This version is stocked with low-friction drifting tires. To change them to grip, open up the wheels in the editor and increase the FRICTION MULTIPLIER. To stiffen up the suspension, open up the FRONT GEAR and REAR GEAR, and increase the STIFFNESS. Enjoy! Many thanks to the creator of this model!!
Note: Changing the friction multipliers to 100 (the normal stock setting) gives some pretty cool roll-over action when overcornering, is harder to handle at higher speeds, but more precise steering at slower speeds.
here is a video of what this truck can do:
