SPECS AS TESTED ON RFG5:
Takeoff Roll = 850 ft
Stall Speed = 113 mph (so realistic you can almost hear the stall horn go off at 113 on clean [no flaps] landings)
Max Speed = 485 full throttle + straight and level
Copied from an actual full scale simulator which looks to be a very nice civilian full scale sim:
"Hold the plane off in the 3-point attitude just barely above the runway until you lose flying speed and the plane sets down. The P-51 doesn't mush but stalls rather suddenly when you lose flying speed. So have your plane close to the runway at this point."
Which actually, in fact, perfectly describes this plane's landing habits on RealFlight G5. Absolutely amazing..
General Information
Wingspan: 37.03 feet
Wing Area: 235.75 square feet
Top Speed, altitude: 487 mph TAS @ 25,000 feet MSL
Top Speed, Sea Level: 401 mph TAS
Stalling Speed, clean: 114 mph IAS
Stalling Speed, landing: 100 mph IAS
CONTROLS
Machine Guns (SUPERDAMAGE-CAPABLE) = Dual Rates Switch down
Rockets (SUPERDAMAGE-CAPABLE) = Smoke / Retracts Switch up
Smoke Trail = Turn the Flaps Knob just barely a small bit from starting position / no flaps. Flaps function normally after this knob setpoint.
Wheel Brakes must be added by the end user, although up on the 3-Pos Switch applies a brake on the tailwheel. Left and right camera panning is also controlled by the 3-Pos Switch on the camera "Cockpit A".
Test out our "Little Friend" at the WEAPONS TESTING RANGE!!!!
TOO MUCH FUN, KNIFE EDGE!!!! Enjoy!
General Information
CONTROLS
