Piper Cub 33% Scale Electric_AV
This aircraft is for RF6. The airfoil is under a different name and has different physics in G5.
It is an exact duplicit of my gas model and is set to run on either engine with no changes required to the physics. The only change that needs to be made is changing engine sound to match the engine.
You need to import both of the models, if you want both engines, because they both have a custom engine.
My other model is located here. https://forums.realflight.com/index.php?resources/16828
Please rate and leave a comment.
Piper Cub from RealFlight 6
