The Stuka JU 87G! Stuka “Kannonenvogel” (Cannonbird).
Revamped color scheme (download CS seperately) and added "cannon loads" to the cannons and guns in the rear! Cannon pods recoil with each round fired! She pumps iron!
(Made a modification to the cannons so that there is muzzle flash when cannons are fired! Go to Aircraft Editor and go to "main wing", then "mid wing", then to "cannon aligner pivot", and go down the menu to "cannon smoke". Change "yellow smoke" color to Orange and set the smoke values to: Smoke Size Rate = 165, Starting Opacity = 100, and Starting Size = .30) She's belchin' muzzle flash now when fired (see pics)!
Cannons on CH 7, down to fire cannons and up off. CH 8 down fires the rear guns. Brakes on up elevator, drop the tail before applying brakes.
Thank you to Keith Lowe for the original AV!
