Plane adjusted to performance specs, slightly more overpowered
Crew: 1
Length: 7.29 m (23 ft 11 in)
Wingspan: 8.10 m (26 ft 7 in)
Height: 2.80 m (9 ft 2 in)
Wing area: 12.8 m2 (138 sq ft)
Aspect ratio: 5.13
Gross weight: 855 kg (1,885 lb) for aerobatics
Max takeoff weight: 975 kg (2,150 lb) for ferry flight
Powerplant: 1 × Vedeneyev M14P 9-cylinder radial engine, 268.5 kW (360.1 hp)
Performance
Maximum speed: 305 km/h (190 mph; 165 kn)
Stall speed: 100 km/h (62 mph; 54 kn) [3]
Never exceed speed: 450 km/h (280 mph; 240 kn)
Ferry range: 705 km (438 mi; 381 nmi)
G limits: +9, -6
Roll rate: 345 degrees per second
Rate of climb: 15.5 m/s (3,050 ft/min)
Wheel brakes on 3-pos switch, DOWN for BRAKES OFF, MIDDLE for PARTIAL BRAKES, UP for FULL BRAKES. Great suggestion by cam17!!! For a more realistic roll rate, use low rates (or fly "accordingly"). Enjoy!
Crew: 1
Aspect ratio: 5.13
Performance
G limits: +9, -6
