It will highlight the CG position in the diagram of the plane. You will see it move as you edit the x,y,z values. To move it backwards or forwards use the Y value. You can move it up and down with the Z value. Normally you don't mess with X but it will move it side to side.
You will find CG Adjustment under Airframe NOT Fuselage
