I tried several more things.
I flew the L-39, out about 10 miles, from Flight school HD, runway. Plane Shaking prominently:
1) Hit "P" to save that position, Hit reset button. (which just resets aircraft, to the point, it was, when I hit "P". As I suspected, the plane was still shaking.
2) Turned Physics to Beginner. NO HELP
3) Reset Graphics to Lowest setting. NO HELP
4) Zeroed out wind and turbulence. NO HELP
5) Full Screen vs Windowed screen NO HELP
As far as, the nose camera, not shaking....I don't think, its actually attached, to the plane. I didn't see it in the aircraft editor. (L-39)
The reason I felt, it is NOT CAMERA SHAKE, is because, if it were camera shake, the farther, the objects are, from the camera, (field of view) (mountains) would seem to shake more,(yards, or miles, as opposed to, inches) than things closer to the camera (cockpit interior) NOT THE CASE!
If its AIRPLANE SHAKE, since the camera has mass, while the plane is shaking violently,(as is evident) The camera MOUNTING, seems to have, a DAMPENING EFFECT. Which would make, the near by objects,(inside) seem to shake, violently, while objects farther away,(outside) shake less, AND, OUT OF SYNC. WHICH SEEMS TO BE THE CASE!
FROM THE MINDS OF FROGS WITH NO LEGS CANT HEAR
GO TO THE EDITOR AND TURN OFF THE BRAILLE HOMING DEVICE
