Excellent model. Want to use it but...
I downloaded the file from the swap pages, imported it successfully and when I selected it under the list of custom aircraft, RF started to create the DDS file and then I got an unexpected error message, and the program closed. I then ran the program again, selected it again,, and "Invalid Data" errors started to appear one next to the other as I clicked the ok button. After all the error were acknowledged, I got a heli with a white canopy (blank), and only the head, main blades and tail blades had the proper look.
When I go to flying it, the heli appears with canopy disengaged from the frame aside it on the floor, and when I take off, I have the heli flying without the canopy, with a white frame with no details, and the canopy on the ground.
Any idea why this is happening?
I'm using RF6.5
Thanks,
David
I was able to import the file. I read the following tutorial post:
https://forums.realflight.com/showthread.php?t=28643
Followed the steps and still had problems. I then selected the Sod Farm photofield, and the problem was solved. I first didn't select Sod Farm because I was using a photofield, but it seems Sod Farm has the magic.
