Aw, c'mon, looks like I got a 90%Junkboy999 said:You scored a 50 % on that one Jeff..
The other way is with an Alpha channel added to the map at time the modeler is finishing up his final touches. I'm thinking lest then 10% of the models use this technique.
Im wanting to edit the Yak, Impala, or Electrifly RiotJunkboy999 said:I not a gimp user. It gave me so many problems, I went back to an old version of photo shop
But it goes something like this. The main image has the tine color on it and another layer ( the Alpha Layer ) is all shades from black to white. The amount of gray scale controls how transparent that part of the map is.
Here is two picture of a good model that has a big alpha layer mapped on it for the semi transparent covering. You can see where I made a squiggle line in red on one wing in the tint layer.
The layer below it is in a gray scale and it again controls the transparency of the map.
But again remember that the modeler HAD TO ASSIGN THIS PART OF THE MODEL to use the alpha layer on the map.
What model are you wanting to edit. ??? I can check to see if it uses an Alpha channel..
