D
E-flite Air Tractor_EA
I imported this plane into RF Evolution and when I spawn the plane the spray bar automatically detaches and falls on the ground. Any idea what's going on? Seems to function ok otherwise.
Try hitting different switches one at a time OR turn the knob, THEN hit "RESET". Reading the description on the biplane, it`s the knob that detaches /attaches it. I`m not sure about the low wing version. It would be nice to know what plane you have exactly, and what TX you`re using.
Overview Updates (1) Discussion
WatchAdd bookmark
Eflite Air Tractor 1.5m
Setup for the InterlinkDX
Sprayer = A switch
SAFE = B switch
Rates = C switch
Flaps = D switch
Trim tab = Knob
Sidewindow open/close = G switch
Detachable Sprayer = H switch
In Realflight 9.5S the sprayer falls off when you turn it on, or falls off right away depending on the airfield. The plane flies very sporty in RF9.5S. I also loaded it on Realflight 8 and the sprayer works. The plane flies much more sedate in RF8 as compared to RF9.5S.
Well...
I was really looking forward to having a great sim experience for my eflite AirTractor with RF Evolution. Sadly, even getting RF to work on my computer was a real PITA. Anyways, this aside my question relates to this Air Tractor simulation.
Having finally downloaded it I have a question.
It flies like a brick. I believe I've found out why?.... The trim tab function doesn't work on my set up - it's stuck in the down position - this I can see visually. Consequently I can't trim the plane (full power sticks neutral the plane nose dives)
I'm using a DX9 Tx with a WS2000 dongle.
Any help appreciated ;- )
Any ideas how to disable the stab trim? - Anyone ??
If using the dongle, you are limited to 8 channels. From the note above by asj5547 (post #22), the plane is configured to use 11 channels....
You could edit it in the Aircraft Editor to make some items non-functional. It will take a bit of sleuthing to trace what controls what, in order for you to do that.
Aha !! Thanks Flapper - you've set me on the right track....
I've found that channel 10 controls the stab trim, and by resetting the trim from 0 to -100 renders the trim tab neutral. The sim now flies just fine. If only I could get the sprayer working !!
