Aircraft Master said:
Numbskully, the edit that I have can hit the speed barrier level.
Not if you are only going 3600 kph!!
Look. Oh and also, Numbskully, Turn your units to metric to test it. The maximum speed in Metric Units is 3600 KPH or 1000 Metres per Second.
Hugh?
So by that do you mean that you can't go faster?
Or because I'm using mph I'm really not going the speed my Nav. Guide is reporting?
I don't understand your point?......
2355mph\3790kph is still 2355mph\3790kph
weather your Nav. Guide shows it in kph or not !
Right???
It IS showing it in mph !
And all of the mph to kph to Mach conversions I have done.......... are accurate!!!
And why should I use metric ?
(I live in the U.S.)
If there is a “limit” as to what the Nav. Guide will show in kph
why would I want to use metric anyhow???....
In a thread thats titled : “The Fastest Jet in RF”
that also requires a screen shot of the Nav. Guide .
why are you even using an option that has a built in limitation?
Sounds like you've hit the Nav. Guides metric display “barrier” if you ask me!
(IMO....thats a “Bug” in the program)
If RF has a 3600 Kph limit in the Nav. Guide (again I don't ever use metric so I wouldn't know)
maybe YOU should switch it to mph!!
MAYBE you ARE going faster !.........
And your Nav. Guide is just not showing it!!!....(provided that you are still flying ,not dieing)
EDIT:
FUNNY ?.....
My Nav. Guide goes beyond 3600 kph !
Maj. Numbskully said:
(however I doubt that you'll do it with the SR-71
Guess I was Wrong !
This is MY edit of the SR-71
..........3787kph\2353mph\Mach3+ .......Catch Me........If ya Can
