G2 Update Problem
jimli
Banned
RealFlight G2 If the version is not 2.00_637 .
If it is an older version Whether Energy through patch updates to 2.00_637 ?
csgill75
Read the thread I referred you to in the other thread you started. Once you have the file ready to run it you just run the file and let it update. If it doesn't work then you may have an incompatible version of RealFlight G2 which means that you cannot update it. Also if you are using Windows 7 64 bit, it will not work either. You need to have windows 7 32 bit only
