nice build for us older guys haha , Giant Slow Ultra Sick 76I had my 76th birthday in November so I thought I'd slow down in a big way. I haven't started the project yet so nothing to show, but the title says it all. Right now the plan is for a 2 meter e-Flite look-a-like.
that is usually due to high lift slow flyer wings to counter the climb and to make it more stableGot a question for you guys. The motor in the Slow Stick has a 10 degrees downward angle, so what is that supposed to do. I think I know but I need some confirmation on it. (I don't have it modeled in yet)
I wasn't sure what it was for, but that makes sense. But being 10 degrees (in the physics) seemed like a lot.that is usually due to high lift slow flyer wings to counter the climb and to make it more stable
Not for the amount of lift that the RW planes wings creates, especially in relation to its weight, which is practically nothing.I wasn't sure what it was for, but that makes sense. But being 10 degrees (in the physics) seemed like a lot.
It'll be interesting to see how it works for my plane when I do the physics for it. I think I'm going to rough-in the plane and then do the physics before I finish it. Has anyone else bought the E-Flite downloadable version? It's just 3 bucks.Not for the amount of lift that the RW planes wings creates, especially in relation to its weight, which is practically nothing.
i might be out in left field but i found that when transfering some physics long time ago ,but could it be the reciever that comes with the real RC plane ? i know not many like the reciever that comes with it and usually put their own in to fly it as they like . here is one you tube channel that mentions itI ran into something I don't understand so maybe one of you can explain it to me. When I first started this project I saved the "real" E-flite Slow Ultra Stick 1.2m physics from the downloadable version I purchased to use as the starting physics for the version I was creating (giant). I was thinking I would start with my E-flite Ultra Stick 1_1m to create the new plane. So what I did was modify the 3d model and then import it using the physics I saved from the real one to move and resize the parts until I got them to align. After that I expected my plane would fly "exactly" like the real plane because I was using the real planes physics. BUT it didn't work out that way, my new plane which the parts fit into the "real" physics didn't fly anything like the real version, which I didn't expect. It was way off so what's the deal, isn't the way it's supposed to work the visual plane fly's exactly like the physics tells it? Even if the visual plane is a box it fly's exactly like the physics tells it. So if you have any idea what I did wrong let me know. I've tried a bunch of stuff but it just doesn't fly like the real version.
Thanks Doug that's definitely a cool video. I guess what I took as gospel since the beginning isn't quite true. I guess I'll quit worrying about that part and just rework the physics when I get the plane resized. I'm about ready to do that but I wanted to talk about what happened to me with the physics before I scaled the plane up the 2 meters (78 inches).i might be out in left field but i found that when transfering some physics long time ago ,but could it be the reciever that comes with the real RC plane ? i know not many like the reciever that comes with it and usually put their own in to fly it as they like . here is one you tube channel that mentions it
if your like me and i am sure you are with the physics , i only used the settings that were suggested with the real RC planes as a starting point and quickly changed it to suit my flying styleThanks Doug that's definitely a cool video. I guess what I took as gospel since the beginning isn't quite true. I guess I'll quit worrying about that part and just rework the physics when I get the plane resized. I'm about ready to do that but I wanted to talk about what happened to me with the physics before I scaled the plane up the 2 meters (78 inches).
Yeah that's pretty much what I do too.if your like me and i am sure you are with the physics , i only used the settings that were suggested with the real RC planes as a starting point and quickly changed it to suit my flying style
I haven't resized the plane yet so right now it's at 1.2m. The only thing I've done is widened the wing to 1.2m and modified the vstab and hstab to fit the position of the download version of the E-flite Slow Ultra Stick 1.2m.This is just me throwing something out there to think about. This may or may not be true. When you scale something up in size the actual surfaces get larger but the one thing that doesn't change is the air molecules. They are still the same size so a larger version usually will fly differently from a smaller size version.
you always have to do appropriate weight to the parts and get a wing loading to match the airplane to the size of the plane your going for , if this helps other wise it is a big floaterThis is just me throwing something out there to think about. This may or may not be true. When you scale something up in size the actual surfaces get larger but the one thing that doesn't change is the air molecules. They are still the same size so a larger version usually will fly differently from a smaller size version.
