Post 2 and post 4 answer those questions.cessna185 said:I still don't get it. None of you are explaining EXACTLY how to do it. Do I do it within the editior? Do I have to make a hole first and then fill it with water?
cessna185 said:I still don't get it. None of you are explaining EXACTLY how to do it. Do I do it within the editior? Do I have to make a hole first and then fill it with water? How would I do that? What is it under in the simulator editor?
phrank said:I suggest a firm grip Major. Something that instills a strong yet conforting sense.
Maj. Numbskully said:you said please .
say to mee......
theres something I don't un der stand
I said please.
follow these
I did the best I caaaaaan......
don't wanna hold your haaaaand
don't wanna hold your hand ....................
and when I told you
I felt happy
inside
but when you said it did not help you
I cried.............I criiiied............I criiiiiied
First make sure that the water is set to "Enable " (yes)
Then you must make sure its set to "Render"the water (yes)(It should be by default, but double check)
Then you just increase the water level (Water Surface Altitude) value until it floods the your chosen area to the level you want
Keep in mind that you can not just make a pond or lake some where and leave lower elevations dry
the water level setting is Global ,( as if the oceans water level has risen)
There are other parameters that can be set like the water color and how far under the water you can see(visibility)
I did i, funny thing is that I wanted to do this in the same place you used for an example LOL
But how can I add waves or undulations on the surface of the water? There is an airport that I really miss on RealFlight and that is a foto realistic beach, dune for slope soaring. I would be great if that could be added.
